1985 2.8 V-6 Camaro
Old Feb 6, 2009 | 01:34 PM
173ciCamKid's Avatar
Car: 1993 Lexus ES300, 1985 Camaro
Engine: 3.0 V-6 lexus, 2.8 V-6 Camaro
Transmission: auto, 700r4 auto
Axle/Gears: Stock
1985 2.8 V-6 Camaro
I have a 1985 2.8 V-6 Camaro. Not sure exactly what its suppose to be(Berlinetta, iroc, z/28, etc...). butbut i had taken the starter off and made sure all the battery connections and grounds were good. I got it started and it idled high, even if the choke was on it seemed too high. but after a few minutes the rpms went down and it wanted to cut out, and i had to have my foot steady on the gass around half way down. now today, i cant even get it started, but it turns over really strong. starting it a seond time had to keep tapping the gas and it wouldn't rev up til a few seconds after i had tapped the gas. any ideas? have new wires, cap, and rotor.
Old Feb 6, 2009 | 01:56 PM
myroc86's Avatar
Car: 86 Camaro
Engine: 350 LT1
Re: 1985 2.8 V-6 Camaro
I had a 2.8 FI with sorta the same problem. It ended up being the fuel pump.
Old Feb 7, 2009 | 12:31 PM
87camarogirl's Avatar
Car: 87 Camaro
Engine: 2.8 fuel injection
Transmission: 5spd
oh boy, my 87 was the same.. the fuel pump is in the tank...if thats the case..its perdy expensive
Old Feb 7, 2009 | 06:57 PM
myroc86's Avatar
Car: 86 Camaro
Engine: 350 LT1
haha yea it was, i just did it myself. Have done 3 of them now and can do it like clock work now.
Old Feb 9, 2009 | 07:11 PM
Axle/Gears: Stock
Thanks for the help. This Camaro has been puzzling me for the last seven years. I had another little problem that doesn't bother me as much as that. When I got it started the first time, after it shut off, I had oil leaking from both sides, draining off the driver side of the transmission, and dripping onto the exhaust pipe of the passenger side. I started it when i had to keep tapping the gas and there was no oil leaking.
Cleotiz
Jan 6, 2018 08:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
E Rod
Aug 28, 2015 05:17 AM
Fronzizzle
Aug 9, 2015 01:15 PM
86Base
Aug 8, 2015 01:34 PM
