Intermittent Starting problem. Help
Old Feb 6, 2009 | 04:37 PM
90IROC305's Avatar
Car: 1990 IROC-Z
Engine: lb9
Transmission: t56
I have a 1990 305 TPI Camaro with a T56. It will start when it has been sitting for awhile but if I have just driven it, it won't start. It just slow cranks(very slow). I have put a new starter, new battery, and new positive cable, and have checked the connections. I cannot figure this out. I don't know the extent of the mods to the engine. It does seem to have a mild cam, and it does have shorty headers. Can someone help me out.
Old Feb 6, 2009 | 07:16 PM
jblong1's Avatar
Re: Intermittent Starting problem. Help
had the same problem till i linked a ford selenoid in with the gm one
Old Feb 6, 2009 | 10:27 PM
lucky14's Avatar
Car: 91 Z28
Engine: 383 TPI
Transmission: 700R4 B&M Hammer Shifter
Axle/Gears: Stock Posi
Check you negative bat. cable for corrsion and good ground. - Repl. if necessay
Check the connections on the starter and signal wire to the solenoid.
My 91 Z28 has a 383 mild cam and required a two new bat cables and gear reduction starter to get it started after I droppped in the 383
Old Feb 6, 2009 | 10:32 PM
r62mcmahon's Avatar
Car: 1989 IROC
Axle/Gears: BORG WARNER /3:70
check battery and terminals. my batt stripped out where terminals screw in.
Old Feb 6, 2009 | 10:38 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Could be a heatsoaked ignition control module....$30 at autozone
Old Feb 17, 2009 | 05:01 PM
90IROC305's Avatar
Car: 1990 IROC-Z
Engine: lb9
Transmission: t56
Finally got it starting. New cables, battery, and gear reduction starter. thanks for the help guys.
92camaroJoe
Jul 29, 2023 07:57 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
