need help firing order
Old Feb 7, 2009 | 01:26 PM
maniacZ28's Avatar
i have a 91 z28 305, anybody know whats the firing order? does it matter where i put the plugs in? or they just have to be in order? thanks in advance
Old Feb 7, 2009 | 02:18 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: need help firing order
sbc firing order is 1-8-4-3-6-5-7-2 in a clock wise direction. No. 1 on the dizzy will normally point towards the no. 1 cylinder, which is the first one on the drivers side of the car
Old Feb 7, 2009 | 03:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The spark plugs don't have to be in order, but the spark plug wires need to go from the distributor to the spark plugs in the proper order.
Old Feb 7, 2009 | 04:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The above information is a little misleading to someone who isn't mechanically inclined.
18436572 is the firing order. The rotor in the distributor turns clockwise.
#1 cylinder is the one that's the most forward. On chev's, that would be the front driver's side plug. Chev cylinders are 1357 on the driver side and 2468 on the passenger side.
#1 on the cap can be anywhere but it depends where the rotor is pointing when the #1 cylinder piston is at TDC. Normally, it's in the 5 o'clock position roughly pointing towards the #1 cylinder.
The easiest and safest way to replace plug wires if you're unsure on the firing order or position is to replace them one at a time. It's very common to have 5 and 7 mixed up because the wires and plugs are next to each other.
If you've pulled the distributor, you need to drop it back in with the rotor pointing to the proper post on the cap in relation to which cylinder is at the firing position. Normally it's all done with #1 at TDC. If the rotor isn't in the correct position and needs to be turned, it's possible the oil pump drive also needs to be turned using a screwdriver so they both line up.
KCG
Jun 24, 2020 04:33 AM
djmarch
May 8, 2016 11:32 AM
camarohelp
Sep 22, 2015 03:19 PM
webeeZ28
Sep 14, 2015 12:00 PM
