Question about spark plug wires... Should I get new ones?
Old Feb 7, 2009 | 03:41 PM
fearthisinc's Avatar
Ok.. so I started up my Camaro cuz my truck had to go in the shop so i needed a car to get to work and whatnot.. I realized that starting was not firing up as quickly as it used to and while driving it seemed like something was missing.. well i was doing a little work when i realized i heard this clicking coming from the engine.. sure enough i noticed that the spark plug wires were leaning on the headers and i saw sparks, well a blue line that would come out of the wire and attach to the header.. for now i have readjusted the wires so they are not touching and as a quick fix put electrical tape around the wire.. will this be ok the way it is or should i be getting new wires for the ones that are a ltitle burnt? Also could this be the cause for the hesitaion and the reason the car wasnt starting up as quickly as usual? Also is there anything else i should be checking?
Old Feb 7, 2009 | 04:52 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Question about spark plug wires... Should I get new ones?
Well as far as the hesitation the spark plug probably isnt to blame for that. Possably the hard starting but shouldnt really make all that huge a difference. I would deffinetly replace the wire because even if its not arching the wire inside may still be damaged from the heat.
Old Feb 7, 2009 | 05:05 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Electrical tape won't stop the 40KV (+/-) that's firing the plugs. Invest in some good wires and keep them away from your exhaust. You probably want to do the plugs too while you're at it. They may be fouled from the misfiring.
evilstuie
Feb 28, 2016 03:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Bryan F
Aug 18, 2015 02:28 PM
