Gas smell on start up
Old Feb 8, 2009 | 09:36 PM
gulf_coast_228's Avatar
Car: 1992 Firebird Trans Am GTA
Maybe my inexperience is showing really bad here but I'm at a loss as to what is causing this. Any help is appreciated. When I first start my car after it has been sitting for around an hour I can smell gas coming from the vents. The gas smell is mixed in with an exhaust smell too. What do I need to check here, what could be causing this? Once the car is running I don't smell gas anymore. I'm not going to rule out bad injectors, but what else would cause this?
Maybe this is related, maybe it isn't, but also after running for a bit when I come to a stoplight the RPMs drop to around 700 to 500 and the oil guage dips down to just above the 1/4 mark (there is also a vibration). I usually smell exhaust at this time as well, though not with the gas smell. I've removed the AIR system and smog pump in the past since the catalytic converters were removed well before I ever got the car.
Any ideas?
Old Feb 9, 2009 | 09:37 PM
Re: Gas smell on start up
Any suggestions?
Old Feb 9, 2009 | 09:50 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Axle/Gears: 3.42 posi
do you have tpi or tbi?
Old Feb 9, 2009 | 10:42 PM
I completely forgot to list the car having the problem. Car is a 1992 Firebird GTA, 5.7 350 TPI. If I had a carb I'd start looking there but I don't..
Old Feb 9, 2009 | 10:55 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
take all ur injectors out and check the o rings on them my friend had the same problem on his civic he had one bad o ring and you could smell gas
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
BurlyChev
Aug 16, 2015 09:08 PM
