TPI FPR diapharm part#
Old Feb 9, 2009 | 02:41 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Does anyone know the part number for a tpi fuel pressure regulator diaphram? I have a BBK adjustable reg to install in place of the leaking factory unit but I still need a new diaphram. If anyone knows the part # or where the get it I'd appreciate it, I havn't had much luck locally. Thanks!
Old Feb 9, 2009 | 03:17 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: TPI FPR diapharm part#
http://cgi.ebay.com/85-92-TPI-Fuel-P...ts_Accessories
Old Feb 9, 2009 | 06:10 PM
89RsPower!'s Avatar
thanks thats just what i'm lookin for, shame they don't list the pn, is that an average price?
Old Feb 9, 2009 | 06:14 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
From what I can tell. Mid America Motorworks (who I use for some Corvette parts) sells it similarly for about 80.
Old Feb 10, 2009 | 03:18 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
wow, that is NOT an average price. I was looking for one too, lucky for you I bookmarked the links...atleast 1 of these should be near you and any store should be able to order it for you if they don't have them in stock...
Autozone
AdvanceAuto
O'Reilly Auto
Old Feb 10, 2009 | 11:22 AM
89RsPower!'s Avatar
Thanks for the replies, looks like I'll try autozone.
Old Feb 10, 2009 | 01:52 PM
HCR13's Avatar
Car: 1987 Trans Am
I'm gonna go to the junkyard and pull one off a car because I'm not certain if thats the culprit of my issues. Those diaphragms are a 80's GM staple. They are the same piece in almost every GM car, you just have to fine the FPR... I think I'll pull one of a v6 thirdgen and pay like $1. If thats the issue, then I guess I'm buying a new one...
Old Feb 10, 2009 | 03:20 PM
89RsPower!'s Avatar
yeah I have several spares around, all in tpi fuel rails, they just tend to be in horrible shape due to age, if they don't tare comin out you're lucky. The one im replacing was very brittle but still in one piece. It doesn't look too bad to the naked eye but when I was taking it apart I noticed liquid fuel in the vaccum line, a sure sign of failure. It didn't show any symptoms though, so I'm assuming it must have been a small leak. It's one of the final things I need to finish up my engine swap so it will defently be replaced with a new 1. I just don't want to spend a fortune on it
Old Feb 10, 2009 | 04:28 PM
formulaerik's Avatar
Car: 1991 Formula
I bought mine from advance auto parts or auto zone a couple of years ago
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
wayshegoes
Aug 17, 2015 12:00 PM
Sanjay
Aug 12, 2015 03:41 PM
