car died after startup, no lights, wont turn on
Old Feb 11, 2009 | 02:52 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
First let me say that I am currently deployed right now and my father has been taking care of the car in my absense. He went to start it and seconds after starting it, he said it just died. No spit or sputter it just died. He tried turning on the lights, it wouldnt happen. It wont turn over, and the battery isnt 6 months old. He tried jumping the car and the lights still won't turn on.
I was thinking alternator, but it would at least have enough power from a jump to start and then die again. If it was the grounding cable then it wouldnt explain why the lights won't turn on.
I know trying to diagnose this when I am not there is prettyhard but I have a custom cam and other goodies i am putting in the car once i get home and want to make sure it is in operable shape.
Old Feb 11, 2009 | 04:38 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: car died after startup, no lights, wont turn on
He might want to clean and tighten the battery and starter connections.
Old Feb 11, 2009 | 05:39 PM
Car: 92 Camaro
Axle/Gears: S60 373
Already checked......somebody suggested checking the fuzes so ill tell him to check those
Old Feb 12, 2009 | 02:20 PM
Car: 92 Camaro
Axle/Gears: S60 373
Talked to my fatehr today...says it started right up??
Old Feb 18, 2009 | 02:06 PM
Car: 92 Camaro
Axle/Gears: S60 373
Alright its doing it again!!
Old Feb 18, 2009 | 08:16 PM
Car: 92 Camaro
Axle/Gears: S60 373
bump
Old Feb 18, 2009 | 08:21 PM
50bmgshooter's Avatar
must be a bad connection I would check the cables, and both sets of connections on them.
Old Feb 19, 2009 | 03:51 PM
Car: 92 Camaro
Axle/Gears: S60 373
already cleaned and tightened down
Old Feb 21, 2009 | 01:23 PM
Car: 92 Camaro
Axle/Gears: S60 373
Positive battery cable shorting out against head......
Spyder_TheGamer
Dec 25, 2015 05:07 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Wade787b
Sep 29, 2015 01:15 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
