distributer help car wont start
Old Feb 15, 2009 | 09:54 AM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
so yesterday i did a simple distributor rotor and cap swap. put everything on correctly and it wont start. i triple checked the rotor, cap, ground, coil and spark plug wire order and everything is correct and should start but its not and im stumped and in need of help
Old Feb 16, 2009 | 10:04 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: distributer help car wont start
Well something not quite right first though alittle info on the car is it a HEI type distributor or one with a remote mounted coil? Next to be clear all you did was dissasemble the distributor itself to swap parts? No timing adjust or plugs wires or any other kind of work for that matter?
Wade787b
Sep 29, 2015 01:15 PM
Brcharrelson
Aug 26, 2015 07:47 PM
TheExaminer
Aug 26, 2015 04:59 PM
L98GTA87
Aug 5, 2015 11:02 PM
