finally putting motor together
Old Feb 16, 2009 | 10:44 PM
afida15's Avatar
I need help with my compression ratio.I'm not sure if my block is decked or not. i traded my set of 302 dome pistons for a set of brand new Forged Trw l2256 pistons already on a set of rods with new rod bolts and resized. they are 4 valve relief, summits site says they are +6.10cc and have a compression distance of 1.563. can anyone tell me or atleast a ball park estimate of my comrpession ratio? im using 882 heads that i just had screw in studs and guide plates put on. im also using a stock 3.48 inch stroke crank.
Old Feb 17, 2009 | 03:20 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: finally putting motor together
What head gasket?
Old Feb 17, 2009 | 07:00 PM
afida15's Avatar
i need some help on that i was gonna ask that question but forgot. i want one that will help me get the most compression since im using 76cc heads. i know it wont help out much,
Old Feb 17, 2009 | 07:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
With a minimal 0.030" between the piston face and the head, you'd be at around 9.1:1. It'll vary very slightly with how far down the hole the pistons are, and the bore and thickness of the head gasket, but you won't be able to get a whole lot better than that.
Old Feb 17, 2009 | 07:30 PM
afida15's Avatar
alright much appriciated. i really wish i had the money for aluminum heads right now but theyl have to wait. what cam would be good with those heads, ive got a weiand single plane intake. i was thinking like a comp xe284 or 274
jhawkeye
May 25, 2022 06:33 PM
Polo Z03
Sep 10, 2015 06:43 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
slade5612
Aug 11, 2015 07:19 PM
Leggman1
Aug 6, 2015 04:15 AM
