pull engine codes with out it being scanned?
Old Feb 17, 2009 | 07:14 PM
my90bird's Avatar
Car: 1990 firebird formula
Engine: 5.0 tpi
Transmission: t-5
on a 90 formula is there a way to pull engine codes with out a scanner?
Old Feb 17, 2009 | 07:22 PM
Seanmay1's Avatar
Car: 89 Firbird Formula WS6
Engine: TPI 305
Transmission: T 5
Axle/Gears: 3.45 Posi 9 bolt
Re: pull engine codes with out it being scanned?
yes you use a paperclip and cross two terminals over (they are the top two on the right of the plug) and count the flashes of the check engine light,im not to good at describing things so im sure somebody can give u better details on counting the flashes its a little confusing at first
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
yes you take a paperclip and stick it in certain ports of the scanner plug in. I don't remember what ports anymore, but that's how i did it for my 88.
Old Feb 17, 2009 | 07:23 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
got beat to it.
Old Feb 17, 2009 | 07:24 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
the 2 ports on the top right side of the ADL connector is what you want to cross.
Old Feb 17, 2009 | 07:52 PM
my90bird's Avatar
Engine: 5.0 tpi
Transmission: t-5
thanks guys,,is there a site I can go to to get the codes?,my light is'nt on but my car is running rich and stalls when I first start it and someone told me to check the the codes anyway
Old Feb 17, 2009 | 09:48 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
i have the book, so if you post them i can tell you what it reads.
first code will be
that reads 12. each code repeats three times.
code 12 is the "initialize" code.
after this, just write down everything.
you know its done because it flashes code 12 at the end.
i got the book at napa for not too much money (probably 20 or so) and it tells you how to do everything you need to know about tuning the computers in OBD I cars.
pretty useful info.
its a haynes IIRC
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
