steering column short please help
Old Feb 18, 2009 | 02:39 PM
ILUVMY89's Avatar
I don't know if this is the right forum but I didn't know where else to put it. But anyways here it goes...
I'm workin on a 89 RS and trying to restore it to running condition. I bought the car with a jacked up steering column so I went out and bought a used 91 column hoping after doing the VATS bypass it would bolt straight up.... wrong. Turns out the one i bought its about 3/4" to 1" too short even after beating the floor mounting plate back a little bit. Actually beaten back quite a lot. I wanted to just weld an extention on it but my rents won't let me because they fear a weak weld is a safety hazard. I'm kind of out of options because if a 91 column won't fit then a 90 or 92 probably won't and I can't use a 88-older because they don't have the VATs keys and I don't know if that would mess with that. Anyway I can make these two mateup fine or am I going to have to sneak around and weld it on anyways. Any help is appreciated.
Old Feb 18, 2009 | 11:29 PM
toomany's Avatar
Re: steering column short please help
Whats wrong with the one you pulled out? If it's just the tilt thats loose...thats an easy fix. If you're having this much trouble putting a new one in, I'd try to rebuild the stock one.
I don't know if (or why) the columns are differnt..but to my knowledge they stayed the same length from 82-92. Are you sure the steering shaft isn't bound up?
It's usually not a good idea to be welding on steering parts, unless you are a certified welder...I wouldn't recomend it. It's not just your life, it's the other people on the road you have to think about too.
Old Feb 20, 2009 | 01:50 PM
ILUVMY89's Avatar
the stock one is dead and gone its onjly a inch short i took it to the shop and had them try to fix it but no use its still a little bit too short
bubbaz28
Sep 18, 2015 02:09 PM
383cam
Sep 9, 2015 06:01 AM
punkmaster98
Sep 8, 2015 09:45 PM
SG91camaro
Sep 5, 2015 10:27 PM
Ian Irvine
Sep 4, 2015 08:08 AM
