How To Remove A/C
Old Feb 19, 2009 | 01:42 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
How To Remove A/C
My clutch finally locked up in my A/C and i'm in need of removing it. I notice that the a/c has about 4 bolts, one is right infront of the valve cover.. i dont know how to remove it, I have a a/c bypass pulley and want to exchange it. I need help asap if thats alright. I just need help to know how to remove my currenty a/c. The a/c system is purged fully and the tube bolt is unbolted, just need to know how to losen belt and remove a/c.
thanks in advance,
Timinsk
Old Feb 19, 2009 | 02:30 PM
federal's Avatar
Car: 1991 firebird/1982 trans am(sold)
Engine: 305/ 383 soon
Transmission: th700r4
Axle/Gears: 10 bolt 2.73
Re: How To Remove A/C
Just need to torque on the idler pulley to get the belt off and unbolt the a/c and pull it out.. Don't really know how much your planning to take of but let me know and I will tell you... I almost forgot you got to put the a/c delete back where you got the a/c out of and put the belt back on...
Old Feb 19, 2009 | 04:38 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
IIRC it's held on with 2 brackets and 3 bolts. Just start removing them and it'll pop right out.
Old Feb 19, 2009 | 07:43 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
i dont know what iirc stands for but i gold the bolt thats inbetween the one near the valve cover and the other near the pole that connects to another bolt, i took nut off the one with the pole connected, dont know how to remove that one and i need help removing the bolt that the valve covers in the way of too...
Old Feb 20, 2009 | 04:22 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
IIRC - If I Recall Correctly
Remove the valve cover.
Old Feb 20, 2009 | 05:50 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
awww crap, i still have smog pump and all these other hoses in the way...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Ironhead38
Sep 7, 2015 02:26 PM
85Special
Sep 3, 2015 04:21 PM
