oil filter upgrade?
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
oil filter upgrade?
I believe I have discovered a helpful upgrade to my oil filter. Someone please let me know if this has already been discovered. I found my filter for my car to be a small filter like PF 454. A smaller one than that was installed on it when I got it. But I have a PF 5, LARGER one, that seems to be a lot larger, therefore better, right? Can I get some input on this idea? Is this helpful much?
Car: 1989 Camaro IROC-Z
Engine: LB9
Axle/Gears: 3.08 G80
Re: oil filter upgrade?
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
The PF454 is good for tight header clearance. I personally will put as big a filter on as I can. The PF 1218 have been sized down a bit also.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If you have the access room, use a big filter. Not all filters are designed the same. Even though they may have the same external size, the type and amount of filter material inside can greatly differ. I personally would not use a Fram filter on anything I own even if the filters were free.
I run a System 1 filter. It's bigger than a typical filter but it's a reusable filter. A couple of times a year I pull it and take it apart for cleaning and inspection.
Car: 1991 Formula Firebird
Engine: Pontiac 355 stroker (305 TBI 4Sale)
Transmission: Pending Manual , 700r4 for sale...
Axle/Gears: Stock... for now
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Car: 87 IROC L98
It's expensive but it's the last oil filter you'll ever buy.
http://www.jegs.com/i/System+1/888/209-312361/10002/-1
maroe624
Apr 16, 2017 08:29 AM
ambainb
Apr 25, 2016 09:21 PM
Navy8125
Aug 21, 2015 09:32 AM
