Sluggish rev and idle
Old Feb 20, 2009 | 04:46 PM
BlackBird84's Avatar
Car: 89 GTA
Engine: 5.7 350 TPI (L98)
Transmission: Stock GTA Trans
I'm having a very sluggish rev and idle couldn't pull it up my driveway with out having it revved up to 3k rpms then it started creeping what could be wrong I think I have a vaccume leak but not sure. when I rev it it laggs a little bit but revs up very slow
Old Feb 20, 2009 | 07:40 PM
thirdgen4me's Avatar
Re: Sluggish rev and idle
Do you have a check engine light on?
Old Feb 20, 2009 | 07:41 PM
Car: 89 GTA
Yes after about 5 minutes or less of idle
Old Feb 20, 2009 | 07:44 PM
Well you need to find out what the light is on for.... You can go to autozone.com and find a write up how. All you need is a paperclip or a wire to jump 2 terminals on the service port connector. The SES light will flash you a code.
Old Feb 20, 2009 | 07:54 PM
Car: 89 GTA
Thanks man will jump the terminals anything else that would cause this problem other than engine light any main components I'm pretty sure I have a vac leak because of lopes in the idle
Old Feb 20, 2009 | 08:09 PM
Well you really need to tell me why the engine light is on! That will tell you/me what part is malfuntioning and I can help you determine what to fix..
gta892000
Aug 11, 2019 11:16 AM
86IROC112
Nov 27, 2015 09:54 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
