1992 camaro rs wont start not even a click
i have a 92 rs it won't start unless i get a screwdriver too the starter, but when i turn the key nothing a slight click by the ds firewall i think those relays are for the fans? but i checked voltage to starter and its good, i changed ignition switch and still nothin. i have been told ignition control module but i don't know where its at and i keep throwing money at sensors and relays and still same results. any help???????
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Check your VATS. There's a tech article on the system linked from the thirdgen.org homepage.
Re: 1992 camaro rs wont start not even a click
i know its not the vats the security light would stay on, its the purple wire from the ignition to the starter its bad somewhere so i ran a push button setup and its running now and i guess a better way to keep my car from gettin stolen. thanks
Well, VATS acting up would keep power from getting to the purple wire.
I'm not sure I'd trust the light to tell me the VATS is okay.
92camaroJoe
Aug 13, 2015 06:07 AM
db057
Aug 11, 2015 10:11 PM
