engine build questions
Car: 82 El Camino
Engine: built 355
Transmission: T-56 upgraded internal
Axle/Gears: 10 bolt 3.42
Ive had the car a few months now and just got the tranny redone now its time for the motor.
Currently its got a stock (mileage unknown) L98 bottom end, assuming stock cam (previous owner didnt know, just pulled motor and installed).
195cc AFR heads
Holley 750 vaccum advance carb
Hooker headers
Edelbrock performer RPM intake
MSD ignition with vaccum advance distributor
Underdrive pulleys.
Strange 12 bolt rear, with 4.10 gears and a posi
Transmission is a T-56
And full spohn suspension
The motor has a couple of oil leaks so im wanting to repair all those hopefully with the motor still in the car. And upgrade the cam while im at it
My question is i talked with summit and they recommended this cam
http://store.summitracing.com/partde...8&autoview=sku
Has anyone ran a setup similar to mine with this cam, if so how were you pleased with the results.
Input is appreciated
195cc AFR heads
Hooker headers
Underdrive pulleys.
Last edited by deadhead1882; Feb 25, 2009 at 12:01 AM. Reason: added induction type
Transmission: 4L80E/4L80E
That's a pretty good cam.
Of course, it'll be completely emissions illegal.
Car: 82 El Camino
Engine: built 355
Re: engine build questions
thankfully, i live 10 miles from mexico and dont have to worry about the smog *****
Car: 82 El Camino
Engine: built 355
Five7kid, or anyone else, what kinda power should i expect out of this combo??
Terrell351
Jun 13, 2021 01:13 PM
