TAP TAP TAP TAP
Old Feb 25, 2009 | 08:51 PM
racerquinny's Avatar
Car: 91' camaro rs and an 87' trans am
Engine: stang eater..slower ones. lolololol
Transmission: 700r4-camaro t5-trans am
Axle/Gears: stock :(
TAP TAP TAP TAP
i have 91 camaro rs 305ci. when i bought it it had a valve tap. at first didnt know it was a valve tap or manifold leak. today i used a stethascope thing and listened. and well it is a valve tap. my friends dad did not know how to fix it.
my question is
how is this fixed and what is the procedure.
Old Feb 25, 2009 | 09:33 PM
TylerP's Avatar
Car: 89 T/A and 97 Formula (sunny days)
Engine: 305 TBI / LT1
Transmission: 700R4 / 6M
Axle/Gears: 89 IDK / 97 3.73
Re: TAP TAP TAP TAP
First,make sure all the exhaust manifold bolts are tight.
Pick up a manual at your local parts store and follow the valve adjusting procedure in the book. If the lifter (not valve) is still pecking it may just be bad and need to be replaced. Then the intake will need to come off. If you need to do this replace all of them.
Old Feb 26, 2009 | 06:00 AM
Re: TAP TAP TAP TAP
i do have a book and i will check it tomorrow, since i have ot work today.
thanks tylerP
Fred SS
Oct 12, 2015 11:27 AM
steimel94
Sep 20, 2015 12:46 PM
gta892000
Sep 16, 2015 12:37 AM
Ragtop Man
Sep 12, 2015 12:23 AM
dimented24x7
Sep 6, 2015 03:51 PM
