1999 blazer s10 wont run
Old Feb 25, 2009 | 09:09 PM
SLOWMARO355's Avatar
Cranks, starts...wont stay running unless im spraying started fluid.
I have good fuel pressure, injector pulse, spider injector is working, egr is good, sparks good, voltage is good, will run smooth untill i stop spraying.
No hoses are loose.
Whats could be the problem?
Old Feb 25, 2009 | 09:19 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Re: 1999 blazer s10 wont run
Sounds like a fuel problem or a vacuum leak, otherwise the starting fluid wouldn't help. Make certain once again that all hoses are connected and there are no vacuum leaks. I had a similar problem with my 99 S10 4x4, I had removed the elbow directly above the throttlebody and neglected to press is on properly again. Looked fine until I looked close and saw the gap at the back.
Old Feb 25, 2009 | 09:34 PM
What elbow? The air cleaner thing?
Old Feb 25, 2009 | 09:37 PM
84Z28406's Avatar
Yes, it goes from the air cleaner to the maf sensor, then through a 90 degree elbow into the throttle body. Or at least it does on the V6 models. I would check that. Will it run at all without fluid?
Old Feb 25, 2009 | 09:41 PM
Oh, the black tube? Wouldn't run hooked up. Only with starting fluid.
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
anesthes
Aug 8, 2015 09:37 PM
cRoe4
Aug 7, 2015 08:46 PM
