ZZ4 TPI jumps to 35 degrees advanced???
Old Mar 1, 2009 | 08:43 AM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
We have a 90 Formula, 350 ZZ4 TPI, with an MSD distributor. When cranking, the timing jumps up to 35 degrees instead of four degrees. He always had to turn it back even when it started. The car kept breaking gears on the flexplate, which consequently tore up gears on the starter. While cranking it, the engine was missing, we thought it might be the chip, so we had a new chip burned by Motorvation, which were based on the specifics of the motor(lift, cam timing, size of the injectors). Any suggestions on how to fix this?
Old Mar 1, 2009 | 09:46 AM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
Re: ZZ4 TPI jumps to 35 degrees advanced???
ignition module or spark timing module maybe. try using a known good one
Old Mar 1, 2009 | 11:57 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The ignition and/or ECM may be wired up wrong.
You could try to sort it out or go for a quick fix of installing an ignition kill switch for starting. You kill the power to the coil while cranking then turn the spark on once the engine is spinning over. It will save the starters and flexplates.
If you were working on your own chips I would suggest trying to reduce the cranking spark to make up for this error.
Old Mar 15, 2009 | 02:15 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Well, after replacing the chip with another one, the problem went away. The mechanic wanted to try to recreate the problem a few different ways at the time I made the post, but was unable to. So, as of now it works.
Perhaps years down the road after I learn how to read the information on the old chip I can figure out why.
It was a hypertech chip, do you guys think the company would take a look at it for free?
Steve78LT
Feb 24, 2016 12:15 AM
Wade787b
Sep 29, 2015 01:15 PM
bamaboy0323
Sep 3, 2015 06:07 AM
cstrobel65
Aug 15, 2015 10:19 AM
Sanjay
Aug 12, 2015 03:41 PM
