White smoke that Smells Gas
Old Mar 2, 2009 | 10:26 AM
Cuban-in-Camaro's Avatar
Car: 1991 Camaro RS
Engine: 3.1L
Transmission: rebuilt 700r4
hey any advice would be greatly appreciated. i have a '91 3.1L v6 has white smoke coming out of the exhaust that REAKS of gasoline( not anti-freeze i am not losing any antifreeze. Antifreeze is still green as can be and no sign what-so-ever of antifreeze in the oil i changed yesterday). it idles horribly in drive or neutral, but if i put it in neutral and tap the gas it smoothes out until the RPM's come back down and then it starts its horrible idle again. the whole time its oozing white smoke the reaks of gas. this past week i have changed: distributor cap, rotor button, spark plugs, spark plug wires, coil, coolant temp. sensor, TPS, IAC, all fuses under dash, and oil. I even drained the gas tank at put Cheveron 93 octane in it. i am at a blank. im pretty sure its a fuel delivery problem, i just do not know what to check. i would greatly appreciate any advice ya'll are willing to give. thank you in advance
Old Mar 2, 2009 | 11:43 AM
8urv8's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6 w/.425" cam (Int. & Exh.)
Axle/Gears: Stock
Re: White smoke that Smells Gas
Hey man, my car had the same problem when I got it. I also have the same motor. I sent it to the shop and they replaced the EGR valve, distributor O-ring, plugs and wires and that fixed it! The white smoke is a mix of condensation and gas. Also make sure you chek your air filter. I think I had the original one in mine! It was nothing but pure black crap and dirt. The day I got the car I drove only 60 miles, just driving around getting used to it, and I had to stop and fill up TWO times!! 26 gallons of gas! So try that and see if it helps. My fuel mileage was horrible until I did all that.
Old Mar 2, 2009 | 03:50 PM
Car: 1991 Camaro RS
Engine: 3.1L
ok, i'll check that. i'll add i pulled a code 13, 33, and 44 at lunch, going to replace my O2 sensor tonight, but what do ya'll make of the 33 MAP
Old Mar 2, 2009 | 04:13 PM
Col.Guyle's Avatar
The erratic idle could have triggered the MAP code.
Old Mar 2, 2009 | 04:24 PM
Car: 1991 Camaro RS
Engine: 3.1L
yeah, thats true, i guess i'll start with the EGR and O2 sensor and go from there. thanks for the input so far 8urv8 and Col.Guyle. any other opinions are still welcomed
Old Mar 3, 2009 | 09:31 AM
8urv8's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
No prob. if I think of anything else i'll let you know.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Strick1
Sep 6, 2015 10:38 AM
Accerrito22
Sep 5, 2015 09:34 PM
