Assembling my shiny new cnc motorsports balanced rotating assembly.
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
So i just received my balanced rotating assembly from cnc-motorsports in the mail. Everything was nicely packaged and Clint at cnc was very helpful. I noticed however that the rods and pistons are not assembled (they are floating pin so i can assemble 'em myself, thats not the problem) however i was under the impression that once an assembly was balanced the rods/pistons must remain together, and that the rod-piston assembly must remain at the same crank journal. I have a bob weight sheet, and the pistons/rods all have their respective weights written on them, but nothing to indicate their respective positions. So i have no doubt that the assembly was balanced, i'm just concerned about reassembling it the wrong way.
Am i totally off base here? are all the component's weights simply averaged together when balanced?
-Zander
-Zander
Transmission: 4L80E/4L80E
In a proper balancing job, all the components are weighed. The heaviest pistons, rods, etc., then have weight removed from them in non-critical strength areas so they all weigh the same as the lightest part. Then the bobweights are established, and the crank balanced.
Re: Assembling my shiny new cnc motorsports balanced rotating assembly.
Thats good news. Out of curiosity how closely should individual parts be balanced? +/- 1g? +/- 0.1g?
-Zander
-Zander
bigjay89gta
Oct 15, 2015 08:04 AM
Linson
Oct 1, 2015 09:50 PM
monte87cortez
Sep 26, 2015 08:10 PM
396, assemble, assemblies, assembling, assembly, balanced, balancing, cnc, code, engines, good, motorsport, motorsports, problem, rotating
