Difference between TPI, TBI & MPI
Old Mar 5, 2009 | 03:15 PM
Tonkatoy's Avatar
Car: 89 Iroc-Z Ragtop, 2012 Toyota Hilux
Engine: 305ci V8 TPI
Transmission: Both Auto's(Wife can't drive stick)
I have searched but can't find the answer to my dumb question. What is the difference between TPI, TBI & MPI engines and what are the pros & cons?
Old Mar 5, 2009 | 04:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Tuned Port Injection - tuned runners, injectors at the intake port of the head.
Throttle Body Injection - a 2-barrel injection system with the injectors in the throttle body, an electronic injector replacement system for a carburetor.
Multi Port Injection - the 6-cylinder system.
Old Mar 5, 2009 | 04:17 PM
Tonkatoy's Avatar
Re: Difference between TPI, TBI & MPI
Thanks just trying to enhance my knowledge so TPI would be better?
Old Mar 5, 2009 | 08:37 PM
five7kid's Avatar
Depends who you ask. . .
The factory used TPI for their higher output engines (not "HO", higher horsepower). That doesn't mean you can't get TBI to make as much power, but the aftermarket doesn't support it as well, and the factory saddled TBI with some restrictive parts (heads, exhaust).
Of course, LT1 > TPI, and LS1 > LT1, so where do you want to draw the line?
Old Mar 6, 2009 | 07:12 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
TPI is the top of the line when it comes to thirdgens, yes.
Old Mar 6, 2009 | 07:37 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
No, there are other MPFI systems that are much better. I'd even take a TBI setup over TPI.
RBob.
Old Mar 7, 2009 | 01:13 AM
five7kid's Avatar
Alright, a mod war!!!!
Tonka, what are you trying to accomplish? What do you have currently?
Old Mar 7, 2009 | 01:57 AM
Tonkatoy's Avatar
Opp's sorry, Just wanting to learn. I have a 89 Iroc-Z 305 TPI Vert, Just sold a 86 TTop TPI
MustangBeater20
Oct 29, 2022 09:20 PM
evilstuie
Jan 9, 2020 08:29 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
