changing fuel pump
Old Mar 17, 2009 | 11:10 PM
  #51
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: changing fuel pump
Originally Posted by jamesh23
it wasnt the pump, changed the relay switch and now it starts, it still overheats though, radiator wont hold antifreeze.
Are both fans running when it overheats? Is the radiator hot?
Old Mar 18, 2009 | 12:44 AM
  #52
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Good for the starting of the car. Now you would have replaced that pump and still have the same issue. Glad we were able to help get you to find the real problem before you started hacking away at the body. As for the overheating problem, you should replace the radiator and the thermostat. According to your other post, you are missing the drain plug on the radiator. No telling what else is bad with that radiator. Also flush the engine with water and get all the crap out of it. Then replace the radiator and thermostat, then fill with coolant. Like I said before - GLAD YOU DIDN'T HACK UP YOUR BODY FOR NOTHING!!!!!!!
Old Mar 18, 2009 | 05:34 AM
  #53
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
wow now just think you hacked you car for nothing. Normally, if you throw parts at something, you start with the cheapest part.
Old Mar 18, 2009 | 08:22 AM
  #54
jamesh23's Avatar
86camaro, i didnt hack my body, i took the pump back and got my money back, but ill remember that next time. I bought a new serpentine belt yesterday, i guess today i buy a new radiator and thermostat, and a water pump? i asked in the other thread too, how do i flush the engine with water? thanks.
edit: looked on autozone.com and a radiator is $120, a water pump is $65, a thermostat is $8, looks like for now i replace the thermostat and just buy a new drain plug for the radiator, and flush the engine out with water if i can. next week ill get the water pump and radiator.
Old Mar 19, 2009 | 01:10 AM
  #55
birdtojag's Avatar
Yeah, we prevented him from cutting up the body and making sure that the pump was what he needed. Turns out it was just a relay. So we are on the good and helping him figure out the problems without just throwing parts at it and hoping for the best.
Old Mar 19, 2009 | 11:19 PM
  #56
jamesh23's Avatar
yes thank you and drknowrs , lol but ya you two guys have helped me the most but thanks to everyone else too.
Old Mar 20, 2009 | 11:55 PM
  #57
birdtojag's Avatar
No problem. This is what we are here for.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
