Replacing carb
Old Mar 6, 2009 | 09:18 AM
1986bluez28's Avatar
Car: 1986 Z28
Engine: 305 for Now
Replacing carb
Going to replace my Quadrajet with a holley. On my 1986 z28. All I have to do is replace the distributor also right. Any help would be great.
Old Mar 6, 2009 | 10:55 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Replacing carb
You also need to check the fuel pressure will probably need to be bumped up (new fuel pump with a regulator). Also unless your swapping on a square bore manifold youll need an adapter. Fuel lines will need to be adapted if your useing a double pumper youll probably want one of the pre made fuel lines for it. You could always swap on the holley spread bore carb thats designed for these cars. Its 50 state legal and would require no changes (except maby fuel pressure).
Old Mar 6, 2009 | 12:40 PM
Car: 1986 Z28
Engine: 305 for Now
Re: Replacing carb
I have a edelbrock performer intake.
Old Mar 6, 2009 | 02:09 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Replacing carb
Fuel pressure? No, that should be the same.
What year car, specs!
- auto tranny? requires modification for the lockup converter
- pull the check engine light, it's a decoration now
Old Mar 6, 2009 | 02:22 PM
Car: 1986 Z28
Engine: 305 for Now
Re: Replacing carb
It's a 1986 z28 305 motor 700r4 trans. All stock. Mecanical fuel pump on block not in gas tank. Is there anything that will give me like a step by step instructions.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
pimp2303
Jul 27, 2017 02:03 PM
midge54
Jan 29, 2017 07:00 PM
gta90
Sep 15, 2015 04:00 PM
