uhhhhh,.........help?
Old Mar 8, 2009 | 07:29 PM
jstringer50's Avatar
Car: 1989 Camaro
Engine: building a 350
Transmission: TH350
Axle/Gears: soon to be 4.10 non posi
so I went to swap springs into my camaro today and I dont see my spring compressor working in the 89 f body setup. I only have a compressor for mcpherson style struts, is there another compressor I need or what?
Old Mar 10, 2009 | 01:07 AM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: uhhhhh,.........help?
If it's for the front springs, you could just unbolt the lower control arms and spindle. set the spring on there and use a jack to raise the control arm back into place. This way the car helps compress the spring and it will line up exactly how you want it.
Old Mar 10, 2009 | 02:21 AM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Just be very careful. If the spring lets go and you catch it with your face, it's gone.
Old Mar 10, 2009 | 02:29 AM
OldYellr325's Avatar
Car: 86 Camaro
Engine: LG4
Just ease it in gently and stand to the side.
thecoolone
Jun 12, 2006 09:02 PM
maroon88iroc
Feb 13, 2006 09:03 PM
