Backfiring at highway speeds
Old Mar 11, 2009 | 12:44 AM
tchernobog's Avatar
Car: 1991 Z/28 1LE
Alright, I've got a '91 z28, 305 TPI. At highway speeds, if I'm at a relatively constant speed for 10 miles or so, and I let off the gas completely, my car, I assume at least, backfires rather loudly.
Any ideas? I know it's pretty vague, and could be dozens of things, but I don't even know where to start, except maybe my cat isn't flowing correctly or my car is running too rich, which it shouldn't be, since it just got tuned.
Old Mar 11, 2009 | 01:39 AM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: Backfiring at highway speeds
Check for vacuum leaks. This would be a good start.
Old Mar 11, 2009 | 02:11 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Do you have aftermarket exhaust? If it is sort of a "Crackling" sound it may be exhaust "Cavitation".
tchernobog's Avatar
Car: 1991 Z/28 1LE
Already done, sorry, I should have mentioned that. I made a long trip today, so I gave my engine a good once-over.
Old Mar 11, 2009 | 02:13 AM
tchernobog's Avatar
Car: 1991 Z/28 1LE
Stock exhaust, it's not a crackling, I know exactly what you're talking about and my '78 does it quite well
It's a pretty loud popping noise.
Old Mar 11, 2009 | 02:20 AM
LOL, so does my RS.. How is your timing? Was the ecm plug disconnected the last time it was timed?
Old Mar 11, 2009 | 07:09 AM
Vader's Avatar
Make sure the EGR is functioning properly. The chambers may be getting very hot after lean cruise.
Old Mar 11, 2009 | 11:00 PM
birdtojag's Avatar
Sounds like what Vader is talking about. EGR cools the cylinders down to cut down on the NOx emissions. Also, timing could be an issue. Let us know what you find after you check these items.
Old Mar 11, 2009 | 11:53 PM
tchernobog's Avatar
Car: 1991 Z/28 1LE
Yea, I meant to check if there were any codes today, but I got caught up claybarring, spray waxing, waxing and sealing the whole car.
Oops haha, I'll check first thing tomorrow, and let you guys know.
Old Mar 13, 2009 | 11:19 PM
tchernobog's Avatar
Car: 1991 Z/28 1LE
Alright, update time.
Pulled the engine codes tonight. Got 2, EGR code and O2 sensor code. However, I also noticed that my speedometer is off. Up to about 25-30, it's accurate, but past that it starts gaining speed, up to about 15mph off around 55.
So, I'm gonna replace my VSS, since I know the VSS relays idle/AF information to the EGR.
Old Mar 16, 2009 | 06:38 PM
birdtojag's Avatar
Which O2 code did you get? Rich or lean?
Old Mar 16, 2009 | 06:43 PM
tchernobog's Avatar
Car: 1991 Z/28 1LE
Rich.
Bubbajones_ya
Jul 6, 2024 08:32 PM
tyeo098
Nov 30, 2015 06:27 PM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
85 Jimmy
Sep 30, 2015 07:56 AM
