My Camaro i changed the engine and Transmission!
Well I will start with 3 months ago i changed too the 3.1 engine and transmission out of my car! 03-05-2009the other one back in same 3.1 ! Does anyone know why the service is on ? The only thing that isn't different is the oxygen sensor! Today is the second I fired it up run's really smooth ! The reason i replaced the engine and transmission was a stalling issue i had a bent distrubater , I let some one work on it , then I took it to a mechanic he said it wasn't the computer or the fuel! But in the injectors , by replacing the engine did it correct all the problem ? Is there a reset button in the car the ecm? Who sell's good ECU? I want one from a third part ! Well gonna try and get the driveshaft back up ! Is there an easier way to take out the yoke ?????????? Thank you Sincerly Jack
Car: 1986 Sport Coupe
Engine: 305 Carbed
Transmission: th700r-4
Re: My Camero i changed the engine and Transmission!
whats a Camero? I thought we were all about Camaros and Firebirds...
also, shouldn't this be in the v-6 boards instead of vendor reviews?
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
