91 Firebird Won't start.
Old Mar 12, 2009 | 03:30 PM
BJCFireBird91's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 V8
Transmission: Automatic
i am new to the F-Bodies and just bought a 1991 Firebird 5.0 V8 (305) [180,000 miles-1700$] and it was idling yesterday. i turn it off, vacuum it out, and then 3 hours later, it cranks but won't turn over. new dist. cap, rotor, plugs and wires. checked the fuel relay and its working. ruled out the security too. battery is strong. put a little gas into throttle body and still does the same thing. i don't know what could be if it was running fine earlier that day. please help me out with suggestions.. or if anyone has had similar problems with their 305. thanks!
Old Mar 12, 2009 | 06:01 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: 91 Firebird Won't start.
Welcome to TGO
Check for spark. Remove #1 Cylinder spark plug wire - install spark plug tester ~ available for $6 from most stores. Have a helper crank engine over while observing tester. Trace it from there.
//RF
Old Mar 13, 2009 | 01:13 AM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
From where RFmaster left off, you might have a bad coil. But do what he said first. Then check all the spark plug wires and go from there. If no spark from any of the wires, then you may need a coil.
Old Mar 13, 2009 | 06:53 AM
Engine: 305 V8
okay. i will go to Auto zone today and pick up a Tester. thanks for the help and ill let you all know what i find out. i looked at the coil yesterday, think its the original one still so it might be that. had to replace plugs, wires, dist. cap and rotor already. could it possibly be a timing thing? the idiot that had it before thought it was a V6.(don't ask) so two of the cylinders weren't even firing. once again thanks for the help.
theshackle
Mar 5, 2017 06:37 PM
destroyerwes
Aug 26, 2015 08:17 PM
justin57
Aug 20, 2015 07:05 PM
djmarch
Aug 19, 2015 12:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
