Help with noise
Old Mar 13, 2009 | 12:53 PM
olman's Avatar
Help with noise
Just replaced Electric Fuel Pump by the hack method (sorry) car is now running again I need some help with this kind of noise coming from inside the tank is like a distant blender/vacuum cleaner with a bad bearing..you know that kind of noise that is not even..could be the return lines making this noise by dumping fuel back to the tank? or aftermarket fuel pumps make this kind of noise?..(ZERO experience with electric FP)
Old Mar 13, 2009 | 01:37 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: Help with noise
If this is a TPI engine..
The in-tank pump you just replaced produces quite a bit of power.
Well, when you turn the key to ACC/power, the fuel pump
primes the fuel injection system to 45+ PSI before you make
the final turn for ignition.
That is the noise you hear, even the factory pumps hummed.
Id imagine a stronger pump would be just as audible too!
The "hum" gets more audible with lower fuel levels from my observation.
I can hear the pump function when inside the car with my windows up
and radio off as well.
Hope that helps!
Old Mar 13, 2009 | 01:43 PM
manolis1969's Avatar
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
Re: Help with noise
yeah some pumps just whine..another normal condition..
Old Mar 13, 2009 | 02:13 PM
olman's Avatar
Re: Help with noise
sorry, is TBI and is not the hum; irregular noise as deascribed is with engine running
Old Mar 13, 2009 | 02:17 PM
Re: Help with noise
if your fuel pressure is fine and the noise is coming from inside the gas tank..then you are ok
Old Mar 14, 2009 | 01:05 PM
olman's Avatar
Re: Help with noise
just finnished a full hour of trying to make to a/c work .. the engine idle/pick revs so quick i thing the spark plugs job is going to be put aside
the point is I think this new gen of cheap pumps are a lil bit too noise OR the fact that the new "door" to the tank is still open/no pad/carpet in place is ading extra decibels which agravate the old man
Old Mar 14, 2009 | 01:14 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: Help with noise
if you have no padding over that door, you will hear a ton of noise, exhaust, the fuel pump will sound like a hoover, all that goes away when you put the door on
I put the TPI pump in my TBI and at first i was like wow this is loud, slapped on the door and carpet, now it sounds normal.
If you can get a sound clip of what your referring to that would help distinguish it.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
