Correct plug wire routing
Old Mar 18, 2009 | 10:22 AM
tarheel's Avatar
Car: Sold: 1986 Z28 Black/Silver
Engine: LG4
Transmission: 5 spd
Does anyone have a diagram showing how the plug wires were run from the factory?
thx
Old Mar 18, 2009 | 08:17 PM
nitemare70's Avatar
Car: 83 Z28
Engine: Comp Controled 350 w/ carb
Transmission: 5 Speed
Re: Correct plug wire routing
Hello Tarheel. I like the description of U're car. I, too, have black and gray Z w/ LG4 and T-5.I am in process of swapping 350 into it. I do not have a pict of factory wiring 4 plug wires, but I am planning to route them behind valve covers, close to block, under manifolds and to the plugs. My old motor has wire holders bolted under the manifolds that separate them and hold them away from the manifolds. I think it is a lot like the 'Vette.
Old Mar 18, 2009 | 08:25 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
What engine do you have? This is vital to a correct answer... lol
Old Mar 19, 2009 | 05:40 AM
nitemare70's Avatar
Car: 83 Z28
Removing an 83 305 and installing a 90 center bolt valve cover 350. Because of budget and emissions, I am using stock manifolds that route above the spark plugs. If U run wires over valve cover they have to cross exhaust manifolds and AIR injection system also. May cause wires to burn.
Old Mar 19, 2009 | 09:20 AM
tarheel's Avatar
Engine: LG4
Transmission: 5 spd
should have put that in my post, but the engine type is under my signature....LG4.
Old Mar 19, 2009 | 06:55 PM
Air_Adam's Avatar
I thought that might be it, but you never know lol.
When I got my L69, they went straight down behind the heads, then under the exhaust manifold to each plug. There were factory looms bolted to the block to hold the wires away from the manifolds. They look like they were made of a coathanger-sized wire (the looms). I like this routing, looks cleaner. I did this on my 350 after I put headers on it, and it looks good.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
