TRIED TO
Old Mar 19, 2009 | 03:24 AM
ILUVMY89's Avatar
TRIED TO
BYPASS VATS SO I GOT A RESISTOR THAT WAS SAME VALUE AS MY KEY AND CAR STILL WONT CRANK OVER IT THE SECURITY LIGHT COMES ON FOR ABOUT 3 SECONDS THEN GOES OFF EVERYTIME I TURN THE KEY WAT COULD BE THE PROBLEM NOW I NEED TO GET THIS THING ON THE ROAD AGAIN B4 I JUST SELL IT
Old Mar 19, 2009 | 05:48 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: TRIED TO
The key that came with the new column, or your original key?
Old Mar 19, 2009 | 04:57 PM
ILUVMY89's Avatar
Re: TRIED TO
key that came with the column but it doesnt matter cause i put the new passkey box in with the new column and i still wont crank iv done plenty of searches and havent really found anything useful
Old Mar 19, 2009 | 05:17 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: TRIED TO
at this point I'd proceed on the assumption that it's now something other than the VATS.
Old Mar 20, 2009 | 02:34 AM
ILUVMY89's Avatar
Re: TRIED TO
couldnt be before i switched out the columns car started fine with a blank key but all the vats stuff hooked up
Old Mar 20, 2009 | 09:51 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: TRIED TO
What I freakin' headache. I was thinking about the time I swapped steering columns on an S-10, I didn't know what year the replacement column was, and while all my electrical connectors plugged right in, it later turned out that different-color wires were in different spots. So, did you compare this on the 2 columns?
Old Mar 21, 2009 | 02:24 AM
ILUVMY89's Avatar
Re: TRIED TO
no i havent i threw the old one away
Old Mar 22, 2009 | 09:27 PM
ILUVMY89's Avatar
Re: TRIED TO
to the top
Old Mar 24, 2009 | 03:27 AM
ILUVMY89's Avatar
Re: TRIED TO
anyone have this problem before i have done a search with no avail
Old Mar 24, 2009 | 06:41 AM
50bmgshooter's Avatar
Re: TRIED TO
ill bet its the wrong pass key box for the key you got
Old Mar 24, 2009 | 08:56 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: TRIED TO
you have to have a key and a vats that are equal.
the resistor on the key has to match the vats on the steering column. that is located down below on the left hand side near the fuse block. it is a black rectangle. check the resistor on the key and buy the vats that matches it.
also the ecm will either tell the car to look for vats or not. if it says look for vats it reaches out to the black vats box and asks for the code, then it looks at the key. if they match - you get to run. if they dont you car will not start and you will have a 4 minute period in which nothing will happen, before you can try again.
Old Mar 25, 2009 | 03:47 AM
ILUVMY89's Avatar
Re: TRIED TO
the vats box matches the key i got them both from the same guy off ebay... the car wants to start but seems like the gas isnt getting in there and im gonna get anew battery and try it that way this batt is shot i put a resistor so the vats should be disabled now the only prob is when i put the key in the acc the security light comes on for about 3 secs
