Vibration Damper Clearance
Old Mar 19, 2009 | 05:45 PM
Seanmz28's Avatar
Hey guys, I am installing my vibration damper on my engine for the first time. I'm using the old school beat it with a mallet technique, and I was wondering at what point should I stop hitting it. What type of clearance from the timing cover am I looking for, or is it damn near snug up on it. Thanks for the help
-Sean
Old Mar 19, 2009 | 06:03 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Vibration Damper Clearance
I usually do it by putting the crank pulley on, and getting it lined up with the accessory pulleys. It's not possible to put it on too far, at some point it stops going down.
Old Mar 19, 2009 | 06:37 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Sean,
What Ward was saying is a good way of judging it. Thats the same thing I was going through when I first installed my harmonic balancer. Attach the pulley and turn it over with the accessory pulleys attached. Post what happens.
Rabi C.
Old Mar 19, 2009 | 06:49 PM
Seanmz28's Avatar
Well heres the thing, its sitting on a stand in my apartment, so I don't even have the water pump on yet, I figured it was best to beat the **** out of the damper before I thew on the water pump and accessory pulleys. Would you suggest putting on the pump first?
Old Mar 19, 2009 | 07:01 PM
Seanmz28's Avatar
Ok, turns out that was a good idea, I mock bolted the water pump and pulleys on, and the damper looks like it has another quarter inch to go to line up with everything. I appreciate the ideas fellas. I'll let you know how it turns out.
-Sean
Old Mar 19, 2009 | 07:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You want it to butt up to the crank timing gear, which should be on the crank as far as it can go.
Drive it on until it doesn't move anymore. Not sure what you're using for a mallet, but the sound changes noticeably when it "arrives".
A damper installer is better for your thrust bearing. They can be loaned or rented.
Old Mar 21, 2009 | 11:47 PM
Seanmz28's Avatar
Hey guys, i just wanted to say thanks for the help. I managed to get the damper on perfect today. The trick with linning it up with the water pump pulley worked. I had to happy gilmore the damper a couple times with the mallet, but it all worked out.
91 SrS
Oct 7, 2015 04:32 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
