anybody run the first cam bearing installed upside down?
Old Mar 19, 2009 | 08:17 PM
pcfiend138's Avatar
Car: 1992 Camaro Z-28
Engine: L98 5.7L 350
Transmission: TH700R4
Axle/Gears: 3.23 7.5 10 bolt
im rebuilding my engine, which was a 350 tpi from a 92 camaro, and after putting the crank and pistons in the block i rotated it over and but in the camshaft bearings, well when i went to line bearing #1 i was used to the block being upside down so i installed the bearing upside down. how big of an issue will it be if i leave it? its just a hassle to tap it back out but if its necessary its what ill be doing. i was just wondering if anybody had put it in at a different position than 5 and 7.
Old Mar 19, 2009 | 08:35 PM
50bmgshooter's Avatar
Re: anybody run the first cam bearing installed upside down?
i would think that if the oil hole dosent line up withe the galley youll spin the bearing
but thats just me
Old Mar 19, 2009 | 08:38 PM
pcfiend138's Avatar
thats what i thought, but the 1st bearing has two oil holes and the chevy manual for that year said line the holes up at equal distances from the galley, so i was going to go by that, but i did it backwards.
Frozer!!!
Jan 19, 2024 04:55 PM
anesthes
Mar 10, 2016 10:35 PM
camaro71633
Sep 1, 2015 10:24 AM
red90IROCls1
Aug 25, 2015 06:56 AM
rsrmoore
Aug 7, 2015 08:44 PM
