Ignition timing with cc306
Old Mar 20, 2009 | 12:20 AM
danielmonster's Avatar
Car: 1985 IROC
Engine: lb9
Transmission: 700R4 B&M shiftkit
Axle/Gears: 3.42s
What should i set the timing at with the cc306 cam. I'm running a carb and a vacuum advance hei distributor. The specs on the cam are 230/244 duration .510/.540 lift. The advertised duration is 290/306. Operating range is 2000-6000, but it's underrated and peaks at 6300.
If these may be of any help, here are the motor specs:
355
Forged flat top pistons 9.73:1 compression
ported vortec heads
holley 3310 750cfm vacuum secondary carb
summit hei vacuum advance distributor
stealth air strike intake
Old Mar 20, 2009 | 01:59 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Ignition timing with cc306
Best timing is determined by the heads, not the cam. Those Vortecs do best with 30-34 degrees total centrifugal advance.
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 18, 2015 02:28 PM
