Hose help please ASAP (with picture)
Old Mar 21, 2009 | 06:43 AM
littlej2700's Avatar
Car: 1987 firebird formula
Transmission: 5-speed
So ive searched the threads for days now trying to find pictures of my question and its very simple but i just cant find an answer so hopefully the picture goes through but here goes....
in this picture i have pointed out the little coolant routing "t" that goes right next to the throttle body. my question is the vacuum line that attatches to the very top of it where does it connect too? im getting gray hairs trying to figure this out. Any and all help will be awesome
Attached Thumbnails Hose help please ASAP (with picture)-firebird-engine-2.jpg
Old Mar 21, 2009 | 07:08 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: Hose help please ASAP (with picture)
Could be wrong as it's been awhile, but it should go back to the heater box and hookup on a vacuum block there. The piece you are pointing to is the heater control valve. Unfortunately my, GM manual is at my garage and I am @ home. If I get by there I will check....
Old Mar 21, 2009 | 07:11 AM
awesome yeah id appreciate that a ton especially if you can get a pic. when i was diggin through my engine i found a melted hose on the drivers side from something but i cant tell what maybe you could tell me if its related or what it is too but i appreciate the help. thanks
i edited it to say i'll try and get the pic up at some point today haha kinda left that part out with no description.... my bad lol
John
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
There should be a hard plastic vac. line that goes back into the firewall next to the heater hoses.
If you can't find it,just get some new heater hose and eliminate the valve completely.
Thats what I did on my 89.
Old Mar 21, 2009 | 07:15 AM
do you have any pics by chance or is there a diagram i could look at for that stuff... also im really tired after stayin up all night again so im probably just not thinkin straight but any visual aids would be the best but i appreciate that too i'll take a look when i get down there later today and see what i find thanks
John
Old Mar 21, 2009 | 07:16 AM
J91's Avatar
J91
He's right a hard plastic vac line by the heater hoses. Yeah I ended up eliminating that valve as well. Since I swapped motors and went to carb I am a bit rusty on my TPI stuff, Thanks for the correction...
Old Mar 21, 2009 | 08:10 AM
PURPLEFORMULA's Avatar
Car: '89 Formula Firebird
Engine: LSX-451 / 705HP
Axle/Gears: Moser Ford 9" with 4.30
If you eliminate that value, are you going to have hot anti-freeze going thru the heater core all the time causing the heat in the car to be on all the time? Even with A/C.
Eric
Old Mar 21, 2009 | 03:20 PM
J91's Avatar
J91
The heater core has nothing to do w/AC. If you have heat on cold no hot air comes through. I've had two 3rd gens setup that way now.
Old Mar 21, 2009 | 05:03 PM
Stephen's Avatar
Car: 87 GTA
Can't tell where mine ends. It runs into a wire loom, which is factory taped/wrapped at that point.
87 GTA hose
Old Mar 21, 2009 | 06:34 PM
Okay, if it works, but if you delete that value and you have 3 hoses going into it, do you get a "T" valve or how do you route the hose? Which one connect to which one?
Eric
Old Mar 22, 2009 | 07:39 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I eliminated the whole cluster or hoses and the T. Ended up re-routing all my coolant lines for a cleaner effect.
Not the greatest pic of those lines but here it is. Cost a lot of money for the preformed hoses from various cars.
Old Mar 25, 2009 | 12:40 AM
appreiate all the responses but i still cant see where in the firewall near the hoses it goes could anyone maybe get a close up and post it? thanks
Old Mar 25, 2009 | 10:17 AM
Stephen's Avatar
Car: 87 GTA
My video (Post #9) showing it going into a wire loom, didn't help? Follow the loom (since it apparently goes into the loom) & whereever the loom goes, so does the hose.
Old Mar 25, 2009 | 02:53 PM
haha sorry stephen that was my bad my cursor didnt change over your link so i didnt even know it was there. that was exactly what i was looking for even though i cant find a hose or anything coming from that wire loom (my luck), but there were two things and i would love to post more pictures but of course my iphone wont work that way anymore.... i'll try and get a real camera soon to take pics of what i mean but maybe you guys can tell by my description. first one, there is a blueish 3 way vacuum connector that kind of sits over the brake booster with all of those wires and stuff... i have that plugged into my plenum in the back near the distributor... i think i got it hooked up right but who knows... second one, this could be either cruise or something else but it looked like another connector or some kind but the hose rund down under (from driver side) and was melted off probably from exhaust or something (i only say cruise because my cruise doesnt work... any ideas? i'll try and get pics ASAP
Old Mar 25, 2009 | 03:09 PM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
stephen, in your video I seen a small check valve near the rear of the plenum. Could you please tell me where the three hoses connect to?
Thank's
Hotrodboba400
Dec 10, 2019 07:07 PM
tonys91rs
Oct 10, 2015 03:31 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Strick1
Sep 6, 2015 02:21 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
