Push rod guide plates with roller rockers
Old Mar 21, 2009 | 03:50 PM
danielmonster's Avatar
Car: 1985 IROC
Engine: lb9
Transmission: 700R4 B&M shiftkit
Axle/Gears: 3.42s
I have a set of vortec heads that I had modified. The machine shop machined them for .600 lift, put in screw in studs, new springs, and push rod guide plates. I understand that with the vortec heads you need to have self aligning roller rockers. Will push rod guide plates eliminate the need for the self-aligning version. What roller rockers should i get.
Old Mar 21, 2009 | 04:39 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Push rod guide plates with roller rockers
due to the centerbolt valve covers, you'll need narrow-body rocker arms. If you want aluminum full-rollers, I think all of these on the market are "rail" rockers, so you'll hafta replace your guideplates with washers the same thickness. Don't forget the LocTite.
If you use rockers like COMP Magnums, (not Pro-Magnum) you can use the non-rail type and use your guideplates. But using guideplates requires buying hardened pushrods.
gixxer92
Sep 1, 2015 04:32 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
