puff of smoke 305
Old Mar 24, 2009 | 01:43 PM
Floorman279's Avatar
puff of smoke 305
i have a 305 with carb that has about 140,000 miles on it. it runs fine and all but when i first start it, a puff of white smoke comes out of the exhaust. everything works properly but i'm just wondering if this is bad and what could be the culprit
Old Mar 24, 2009 | 01:57 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Re: puff of smoke 305
Most likely valve stem seals are bad. Common culprit.
Old Mar 24, 2009 | 01:59 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
I agree....valve stem seals are worn...I'd bet money on that....won't really hurt anything if it's just puffing some...I wouldn't worry about it.
Old Mar 24, 2009 | 03:52 PM
i was thinking more like rings. which seems more reasonable. it would probly be best either way to just rebuild the motor since its about 22 years old and has never been rebuilt
Old Mar 24, 2009 | 07:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Only 22 years old? Unless it's definitely showing signs of an actual problem, there's nothing to worry about yet.
Old Mar 25, 2009 | 10:32 AM
yea well i figured if it has a problem like that instead of just holding off on it i should just get the motor rebuilt
Old Mar 25, 2009 | 10:35 AM
greatpumpkin_68's Avatar
Car: 1987 IROC & 1968 Nova
Engine: 5.0 TPI & 350
Transmission: 700R4 & powerglide
if it only does it when you first start it then it is the valve seals. i am not trying to tell you what to do, but it would be a lot easier and more cost effective to just replace them and not do a full on rebuild.
Old Mar 25, 2009 | 10:43 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
mine let out HUGE plumes of smoke, and even burned a little going down the road, after an afternoon putting valve seals in the problem is gone. do that first, engines don't need rebuilt as often as they used to
Old Mar 25, 2009 | 11:45 AM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
if its not fouling plugs, i wouldn't worry about it. this is a common problem in small block chevy engines. mine has been doing that for 30K(since i bought it). i also wouldnt waste my time rebuilding a 305, you could rebuild a 350 and have allot more power for the same money.
Old Mar 25, 2009 | 03:19 PM
yea i always thought about dropping one in to. thanks for your help guys
Old Mar 26, 2009 | 10:20 PM
88_TeenTrans's Avatar
Car: 1988 Fire Bird (T-Roof)
Engine: 5.0L 305 TPI
usalllly valve seals are BLACK or BLUE smoke guys cause its burning oil. BUT if it is burning only a little i GUESS it could be white but id consider timing, plugs first then look at the stems. plus those are easier to check first Good Luck
Gunsbee
Sep 7, 2015 07:10 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
