melling m55 pump
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
melling m55 pump
i heard that the m55 pumps are weak now... i already bought it...should i use the m55 pump or get a different one now.... if so which one....
on another site they said that this is the one to equal the old m55a
http://store.summitracing.com/partde...4+&appfilter=1
heres what they say
High pressure performance upgrade for M-55 & M-55A. Standard volume oil pump. The 10553 housing and cover are CNC machined and phosphate coated. Manufactured with pink spring installed for higher pressure (M-55A). To change pump to lower pressure (M-55) install the supplied yellow spring. Includes intermediate shaft with steel guide. The 10553 uses a 5/8" press in screen.
with that being said will this screen fit that 10553 pump
http://store.summitracing.com/partde...5&autoview=sku
its standard volume and standard pressure which i need right....i noticed that it goes to 1987... so does that mean it would not fit a 95 vortec 5.7 block..... what pump... i really need help... thanks...
heres what they say
Re: melling m55 pump
i already found my answer... im going with the 10553 pump... i have the m55 thats the one i have now..... i dont want the 19 dollar thing...... the 10553 is based on the old version m55 and is 80.... the regular m55 pump is on the left and the beefier 10553 pump is on the right.... ive looked and everyone says that the m55 series are a POS and go with the stronger 10553 pump.... the weakness is at the neck and the whole thing is of a much thinner casting..... and this 85 dollar one does not have that weakness... you get what you pay for.....
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
i said M155, not m55, bigger inlet, and befier casting, used on 87+ engines, also a 80$ oil pump dosnt pump oil any better than a 20$ pump
oh my fault.... what about the 10553 pump... its basically the same just beefier..... could i use that also...
Car: 1979 Malibu
Engine: Blown LSx
you could, but 80$ is alot for an oil pump, im running a m55 and a m155 in my engines, no issues whatsoever
i know but i have the money... i would like to have quality parts in my new engine and plus if i get the m155 pump i would have to get another pickup screen because mines is 6.250 the one u suggested is 7.250 and the 85 dollar one i can use my screen... i say its money well spent for alittle insurance... thats me......
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The stock replacement pumps M55 and M77 (BBC) have been made offshore for a few years now. The casting really changed and is weak. For a daily driver engine, they're fine but race engines using heavier oil have been know to break the pumps.
I'm lucky, the pump in my engine is still one of the older castings. Many racers are switching over to the Moroso pump which still uses the older casting or they just upgrade to a billet pump.
Unless you "break" a pump, you can use them over and over. If you spun a bearing or did some other damage inside the engine, open the pump up to see if there's any scoring. Many times there's nothing wrong with it and a simple cleaning is all thats required before reusing.
i cant use my old one because my pump went bad along with 3 spung bearings and metal shavings all in the oil... it wasnt pretty.... basically blew up... thats why i need a good quality oil pump... look at my mods in my sig.its not a stock rebuild thats for sure but its no racing engine..... i will be somewhat racing with this...... i will feel much better getting that 10553 pump....
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
