Timing Specs Needed
Old Mar 24, 2009 | 11:51 PM
PEPSIGIRL's Avatar
Car: 1992 Camaro Rs
Transmission: Automatic
Timing Specs Needed
I am looking for the Ignition Timing Degree for my 1992 Camero v8 305 engine the original sticker that states all the specs is not on the car any longer so if anyone can help I would appriciate it greatly ...
Old Mar 25, 2009 | 01:16 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Timing Specs Needed
First, its spell CamAro, not Camero.
Second, for a TBI engine the initial timing should be 0* before top dead center. Remember you have to disconnect the "set timing" connector on the passenger side first. Its near the A/C condensor and the strut tower. Set the timing, turn off the engine, then reconnect the timing connector and you're good to go.
Old Mar 25, 2009 | 08:17 AM
PEPSIGIRL's Avatar
Car: 1992 Camaro Rs
Thanks Kevin sorry I spelled CamAro wrong I am the middle "woman" between getting info on the internet and my boyfriend the owner so I am sorry for the spelling error. I appriciate the help on the timing we got the car from a impound yard and it had alot of work done on the body like paint ect..also in the fuel system I guess the guy was trying to modify it to look more like a racing car so alot of the stickers for the specs are missing . again thanks for the help
IROCZ1989
Jan 24, 2016 03:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Exxon Limited
Aug 9, 2015 08:13 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
