Help!! Heavy Carbon From Exhaust
Old Mar 25, 2009 | 09:49 AM
bills91z28's Avatar
Car: 91z28 87k Black , rs92 222k Teal
Engine: v8 5.7 Liters , v6 3.1 Liters
Transmission: Both 700 R4's
Axle/Gears: Possy 373 , Single 270
I have 1992 3.1 camaro which I believe is running rich. I have heavy amounts of carbon coming out of my exhaust leaving black residue where ever I park. Does anybody know what could be causing this problem?Please HELP!
(I checked timimg, sensors, and valves. I also had a full tune-up there is no check engine light)
Old Mar 26, 2009 | 06:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
How did you "check" the O2 sensor?
Old Mar 26, 2009 | 10:05 PM
88_TeenTrans's Avatar
Car: 1988 Fire Bird (T-Roof)
Engine: 5.0L 305 TPI
Re: Help!! Heavy Carbon From Exhaust
This could be a dumb question but if its a new car have u ever checked that cat? cuz usally high carbon is #1.Cat #2.Valve seals #3.Timing and O2 sensor
Old Mar 26, 2009 | 11:03 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
How's your gas mileage?
Old Mar 27, 2009 | 09:57 AM
bills91z28's Avatar
HI ! My gas ant that bad ... But not like it was .. at times you can smell it when it's running ( I changed the throttle sencer , map sencer , o2 sencer ) as time goes it's getting worst .. I don't know ....
Old Mar 27, 2009 | 10:02 AM
jv9999's Avatar
Engine: 5.7L/350
I'd suspect a leaking fuel injector. Put a pressure gauge on it and see if the pressure falls off quickly when the engine is shut off.
Old Mar 27, 2009 | 10:08 AM
bills91z28's Avatar
Hi ! o2 sencer... Thats the one that goes in exhaust pipe before the cat .. RIGHT .. I replaeced it when I did my exhaust system three years ago ...
Old Mar 27, 2009 | 10:18 AM
bills91z28's Avatar
Ok ... the exhaust system is three years old thats when I did the o2 senser ... the valves leak just little bit , (it mit take a year to see it on a stick)
Old Mar 27, 2009 | 10:25 AM
bills91z28's Avatar
I'll have to let you know about that ... I'll check that ... ( I was thinking bad throttle body) M.F.I
Old Mar 27, 2009 | 12:12 PM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
As problems like this seem to go...I have to ask, is the residue on the surfaces where youv'e parked by any chance water with black stains/streaks in it, staining the pavement? An exhaust can puke out more water than some folks would think on cold humid days leaving a black puddle. I've had this complaint at the dealerships before.
Unleaded gas by nature leaves a black smeary residue in the tailpipes.
zapr
Jul 27, 2018 06:03 PM
sailtexas186548
Feb 17, 2017 03:07 PM
PurelyPMD
May 5, 2016 04:57 PM
69GTOby
Apr 18, 2016 02:34 PM
david068513
Sep 18, 2015 10:36 AM
