idle problems 406 tpi
Old Mar 26, 2009 | 01:20 AM
406vette's Avatar
my name is dustin i have a 1986 corvette the 350 went out and i had a 406 laying around.its an auto has 30lb injectors a comp cam rebuilt cast l98 heads steel 1.5 roller rockers jet adjustable fuel pressuer regulator heads and intake are ported and pollished its internaly ballanced 2.5 pipes back to resanator tips the only thing i left un touched was the distrubuter for now replaced plug wires.
i had to unplug the cold start injector and finaly got it to run but the idle has to be set at 1300 and still isnt smoth havent driven car but runs strong when given throtle. is the poor idle due to the large engine and outher parts wile still running the stock chip? any ideas how to improve this for the time being should i put the stock injectors in and see what happens. i am ordering everything from moates to emulate log and burn but it will be a while. plans are new heads nitrious pos twin turbo. any feed back appreciated.
Old Mar 26, 2009 | 01:38 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: idle problems 406 tpi
It will improve a lot when you can start burning chips for it. Then you can start troubleshooting any other problems once you rule out the bad tune. Hang in there, the learning curve can be steep but once it clicks your engine is going to start running really great really quick. The only thing I can think of is make sure your fuel pump can handle the demands in the upper RPM ranges. What kind of cam in this 406?
Old Mar 26, 2009 | 02:30 AM
406vette's Avatar
cs nx262H-13 cam specs
intake: lift.462,duration 262
exhaust: lift.480 duration 280
it is made for nitrious and turbocharged applications
Old Mar 26, 2009 | 03:21 AM
406vette's Avatar
113 lobe sep.
i am still missing my temp sensor wire and the sensor that is on the plenum above the fuel press reg beieve air temp? does anyone know what collor they are i coul follow the temp and air sensor wires from the fire wall to find them. have looked for hours.
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
db057
Aug 22, 2015 08:17 PM
Sanjay
Aug 12, 2015 03:41 PM
