lifter adjustment
Old Mar 26, 2009 | 12:17 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
lifter adjustment
so i was pulling into the mall parking lot the other day and as i am getting out, a guy says he likes my car but that it sounds like i need to get my solid lifters adjusted.
first of all, i didnt know i had solid lifters, and that you could tell by listening, but if i do in fact have solid lifters, as the guy said, should i take it somewhere to get it adjusted or can i do it easily.
the car does sound a bit ticky from the out side, not like a lifter tick, but like all of them are making noise.
also, one time i was way down on oil (i had about a quart in the car) and i didnt hear any valve noise, so this furthers my theory that i might have solid lifters.
what do you guys think
Old Mar 26, 2009 | 12:42 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: lifter adjustment
Is your motor factory?? Unless you put a solid roller cam or someone before you whom owned it..you don't have one in there....what year is motor/car??? You might need to adjust ROCKERS but usually they don't come out of adjustment....now people also mistake rockers out of adjustment with exhaust leaks and also, especially on tuned port motors, the ticking of the fuel injectors. Start you car and listen as best you can where the ticking is coming from. Maybe fuel injectors. Does it get louder when under a load (driving) and pressing on the gas??(might be exhaust leak if so)...But give us some specs on your motor and we might be able to help you further...anyways I hope that helped some.
Old Mar 26, 2009 | 02:01 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
I have no idea what's in the motor but it's not stock. The prev owner built it. I figured it was my headers but what do I know. I'll try and get a sound clip up.
Old Mar 26, 2009 | 02:10 PM
Engine: L98 494hp
yeah it could be headers too......does it get louder as you press down on gas pedal???
Old Mar 26, 2009 | 08:07 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
From in the car all I hear is the muffler
With the hood open from the front of the car it's a ticking whirring mess and I can't hear any muffler noise.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
