vortec head swap on 305
Car: 86 iroc-z
Engine: 305 tpi
Transmission: 700r-4
Axle/Gears: 2.73 lsd
i got new vortec heads from jegs and the edelbrock tpi vortec intake manifold the heads did not come with rockers, pushrods and bolts and my questions are: will the rocker arms and pushrods from the lb9 fit into the vortec heads or will i need diferent ones? can i use the stock headers until i come up with enough cash to purchase new ones? and what is a good camshaft for this setup?
Transmission: 4L80E/4L80E
'86 LB9, correct?
You can't use the '86 rocker arms. Vortec heads (these are stock GM heads, correct?) use self-aligning rocker arms, which were used on '88-up engines. Easiest thing would be to buy new ones for '88-up.
The pushrods would be fine, but it's usually recommended to replace them when replacing the rockers. Use '86 pushrods.
A Comp XE262 would be a nice upgrade over the stock cam. You'll need new lifters as well.
Car: 94 Silverado
Engine: 383 Vortec TBI
Transmission: 4L60
Re: vortec head swap on 305
The stock exhaust manifolds should bolt up. If you do swap cams, don't forget to break it in!
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
