mass air flow help
Old Apr 1, 2009 | 01:25 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
mass air flow help
i have 87 350 tpi camaro a have been fixing it up for a few weeks now and cant get it to run right it has a miss at all rpms and dumps fuel o i noticed there is no burnofff when i cycle the key on and off or crank it how do i test a mass air flow and what other sensor and relays are there related to this please help me i am going crazy o yea i was also told if the car runs better when you unplug the mass iar flow sensor its bad so i tried that and the car immediatley shuts off
Old Apr 1, 2009 | 10:22 AM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Re: mass air flow help
Its supposed to shutoff when you pull the MAF plug.....thats how you know the MAF works. And what do you mean it dumps fuel? How do you know its missing throughout the rpm range?
And grammar is your friend. You'll get more responses if your post is done in a readable manner, ie no run ons.....
Old Apr 1, 2009 | 02:20 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Pull the plug on the maf sensor before you start the motor, if it runs better then there is a problem in the maf system but not necessarily the sensor itself. I would start by changing the maf relays.
Old Apr 1, 2009 | 11:38 PM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
if i unplug it while its running it dies also if i unplug it before i start it will not start
Old Apr 1, 2009 | 11:57 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
sounds like a bad maf sensor. take a look inside and do you see the wire glowing hot? sounds like it is sending bad information to the computer, but i only work on map, so there are others more knowledgeable about maf.
when you hit the gas and increase your rpm - once i said moving and got jumped on - as of you are going to increase your engine speed and be sitting still - you increase your flow of air over the wire and it compensates with the computer for the change of circumstances.
running rough when its on? maybe the computer chip is bad and not the right one for your setup. have you checked that one? you cant use a map chip on a maf car. dont even know if they will run at all.
i was looking for maf information and i came on a site which lookedlike a youtube program on how to tear them down. i hit it and i got a message about open or download. thought i would want to see it over and over so i downloaded it.
VIRUS ALERT. it got past 6 firewalls and virus systems. it got me. i opened it and boom it started opening windows all over the place. then i got a virus alert message and was asked if i wanted to delete it. the problem? it was the virus putting that up and eveytime i hit delete i was actually answering YES to a number of questions aout what it could do in my computer. i was saved by 2 things.
the first thing i did was turn of the wireless - but leave the machine on. that is important. if you turn the machine off it will infect everything when you turn it back on.
i closed every window until nothing was moving and looked at the task mgr for action and there was none.
well i turned on every single wall and every cookie hunter i had.
the systems finsihed about 4:00 am this morning. they chased the little bugger down and killed it, but not until it opened more than 20 windows trying to fulfill its programing and getting out into the www and multiply and infect others.
so if you come across this site dont download it and if you do - keep the machine on but kill its internet connection and then run every clean up program you have. it will take 4 to 8 hours to get it hunted down - it goes everywhere.
and when you finally beat it and turn the system off - pull the power plug, pull the battery, and let sit for 5 minutes, which will use up all resident power where it can hide. and yes they do hide, and where they hide they mess things up.
Old Apr 2, 2009 | 01:32 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
the wire for the burnoff does not glow so i dont know where to start i know there is a relay for the maf power and one for the burnoff but all that ***** expensive well for me it is so idk what to try
Old Apr 6, 2009 | 11:35 AM
kcallais's Avatar
Car: 1985 Z28
then you need to check for power going into the burnoff relay. if there is 12v sitting at the relay, you need a new burnoff relay. if theres no power, keep tracing back until you find 12v
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
scotrans am
Sep 5, 2015 04:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
