Sprk plug gap???
Old Apr 2, 2009 | 06:31 PM
Miles87Z28's Avatar
Car: 05 Pontiac Sunfire, 87 Z28
Engine: 2.2 Ecotec, 350 TPI
Transmission: Auto, 700r4 with shift kit
Axle/Gears: No clue, limited slip.
Sprk plug gap???
I am currently running a set of Bosch plus 4 iridium plugs in my 350 TPI with a mild cam and an MSD coil with 8.5mm wires. I have read on here that bosch isn't that highly thaought of with these cars soi am swapping them out for a set of NGK V-groove. Any input on this decission is greatly appreciated. Now for the real question since the car has a cam and all that fun stuff should maybe increase my plug gap from .35 to like .40. Wouldn't this equal a hotter spark??
Old Apr 2, 2009 | 07:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Sprk plug gap???
Read this
http://www.centuryperformance.com/sp...ch-spg-26.html
In my race engine, I run NGK V-groove race plugs and have them gapped at .035". I also have them indexed to keep the ground strap away from the dome on the piston.
Old Apr 2, 2009 | 07:18 PM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
You just need to buy a hotter plug. Changing the gap of the plug is not the correct way of accomplishing what you want.
Old Apr 2, 2009 | 09:49 PM
Miles87Z28's Avatar
alright thanks guys that pretty much covers that issue. car seemed to run fine when i got it with copper core autolites and that was after sitting in a barn for a year. Still don't care for the Bosch plus 4's at all.
Old Apr 2, 2009 | 10:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Too many gimmicky plugs available.
"Our plug will increase your fuel mileage, give more power, etc"
Comparing a new regular plug to some fancy expensive plug will probably show no difference in fuel mileage or performance. Changing out any old, worn, etc plug for any type of new plug will increase fuel mileage.
For a daily driver, I'd recommend a platinum plug just because it will last a lot longer and you won't have to change the plugs as much. Typical plugs on a daily driver should last about 4-5 years at the most. Higher mileage vehicles should change the plugs every couple of years. Plugs are cheap. Don't even bother cleaning and regapping old plugs. Many new cars come with platinum plugs just because they're so hard to change.
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
