how to check the fuel sender and gauge
Old Apr 3, 2009 | 01:31 PM
my90bird's Avatar
Car: 1990 firebird formula
Engine: 5.0 tpi
Transmission: t-5
gas gauge is'nt working,stuck on full,way past full.how do I check to see if the gauge or the sender is bad?
Old Apr 3, 2009 | 03:55 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: how to check the fuel sender and gauge
Disconnect the plug in for the sender(three wires total). Its down beside the tank on the drivers side. Its hard to explain, but its there, it may be taped up on the frame rail. Make a jumper wire or something like it to put inside the terminals on the vehicle side of the plug in. The two you want is the center wire(purple or pink, cant remember) and the outer on thats black. Turn the key on and see of the gauge drops to empty. When you do that, it grounds itself going to zero ohms, thus the gauge thinks its empty. If it still does not move with the key on, its the gauge, if it drops, its the sender. Mine had the exact prob, and it was the sender.
Old Jun 18, 2009 | 06:17 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
thanks I will try this method. my fuel gauge is doing the same thing
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
355sbcTPI
Aug 19, 2015 04:38 PM
