tps falls yes falls
Old Apr 4, 2009 | 09:00 PM
black and blue's Avatar
Car: 87 iroc
Engine: 383 forged tpi w/maf
Transmission: 700r4/3200stall
Axle/Gears: moser 9 bolt 389
tps falls yes falls
a friend stopped by with 89 firebird claimed it ran awful which it did, checked everything over and found his tps starts out around 5 volts closed and .5 at wot, switched sensor still the same. I know its in reverse so i assumed wires were switched traced ALL OF THEM NO SPLICES ANY WHERE!!! So a am just going to pin the sensor to work correctly however I thought I i would ask if anyone would claim there is another fault somewhere that could make this happen that I am unaware of. It is throwing 2 codes 13, 22 engine coolant sensor is the first and tps is the second because I decided I would unhook it for the evening and hope for a direction pointing reply, and it runs fine with sensor unhooked which also suprised me be but..so do alot of things. thanks for the help
Old Apr 4, 2009 | 09:25 PM
Car: 87 iroc
Re: please help this is wierd
its always appreciated
Old Apr 5, 2009 | 06:20 AM
Damon's Avatar
Re: tps falls yes falls
Is this a V6 car? Sometime back I recall a conversation about the TPS voltages on V6 engines working in reverse of how they do on most others.
Definitely fix the CTS sensor. That's guaranteed to run it rich if it thinks the engine is always running at -40*F (off the cold end of the range).
Old Apr 5, 2009 | 11:13 AM
Car: 87 iroc
no it is a 305 mass air tpi bone stock, sorry i should have posted th\at. I will hook the cts up or check sensor if is hooked up but the tps thing isnt correct it should start low closed and rise when open on a tpi
LT1Formula
Oct 8, 2015 08:34 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
FormulasOnly
Oct 2, 2015 05:52 PM
3.8TransAM
Oct 1, 2015 07:47 PM
