Well, I have to do a head gasket on my 305 any way, would these heads be better?
Car: 1991 Camaro RS
Engine: LO3
Howdy ya'll. I have a 1984 K5 blazer with a 305, but the blazer boys dont seem to know HALF as much about heads and 305s as yall, so I hope this isnt a problem for me to post on this forum and ask about something other than a third gen.
Let me beat you all to it, I cant just swap in a 350. This is the only car I have, and I need to deliver pizza in it. I dont have the money for a 350, nor do I have a cherry picker or any other required tools.
I blew out the head gasket on my K5, I think. All i know is a small amount of mosture is getting into the oil, and alot is going right into the cumbustion chamber and being burned. I plan to pull the intake off, and see if I can find evidence of a leak. Assuming I can not, I will throw away the stock one and install a used performer. I have heard of 305 intakes cracking, which would cause my problem.
Assuming I do all this and the problem continues, I will be pulling the heads off and replacing the head gaskets. Since the heads will be off, and I suspect the valve guids are shot, will these heads work well on a 305?
Casting number:
3932441....69-70...350..........76cc chambers
Just would love some opinions and input. Im dirt poor right now, so I have no money to spend on anything
Even the 110 for the head gasket kit is a hard hit
Casting number:
Car: 92 Camaro RS
Engine: 305 TBI
Re: Well, I have to do a head gasket on my 305 any way, would these heads be better?
Stay away from those heads with a 305, they have 76cc chambers instead of the small 58cc chambers a 305 needs, you will lose compression, power and mileage.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Exactly what DartbyU said, those heads are way too big for a 305.
You can get decent gains by porting and polishing the 305 heads if you want to go that route or, if you have the money, check out a set of World "Torqurer S/R" heads with the 58cc combustion chambers for 305 motors. They claim 30+hp just by swapping them in.
Car: 1983 G20 Chevy
Transmission: 4L60
Your 84 Blazer should have 14022601 casting heads on it, if it is still stock. They are one one the BEST 305 castings you can run. They have a tiny 53cc combustion chamber, 1.84/1.50 valves, and 160ish cc intake ports. They work very well on a 305. Do yourself a favor while the engine is apart. Change the timing chain to a double roller and swap the factory camshaft out for a factory 350 cam. The stock timing chains had composite plastic teeth and were prone to failure. Thats the reason mine had to come apart and have the heads re-worked at 175,000 miles. The chain left while the engine was idling and I bent several valves. The cam also had a couple of lobes that were on their way out. The factory 305 cams of that era were very soft.
ambainb
Apr 25, 2016 09:21 PM
NinjaNife
Aug 23, 2015 11:49 AM
