Ever done the Resistance in ECM ground circuit test?
Old Apr 5, 2009 | 03:24 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Did it yield any results?
Last thing I had done before it went funky on me was move my intake hose and MAF around,
Didn’t unplug it or anything.
Can’t get codes to flash and even the use of ALDL gets no data.
I am now shooting in the dark.
This does sound like a good shot.
http://www.cardone.com/english/club/...%2077-0008.pdf
Old Apr 5, 2009 | 11:13 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Ever done the Resistance in ECM ground circuit test?
IM thinking that oucld be why you see post where folks have swaped 2-3 different computers into a car and it sitll wont run right?
Old Apr 5, 2009 | 11:36 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Im kinda confused what is the problem your even experianceing to make you believe you have a bad ground?
Old Apr 5, 2009 | 11:42 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
There are several ground wires going to the ECM. It's unlikely that all of them have failed, but that being said; ground faults are often an ignored issue.
Find a wiring diagram for your car and see if you have power to the ECM (2 places, orange & pink/black wires). Does the SES lamp light at any time at all, like when you turn on the ignition, or if you disconnect the ECM? If not then check the gages fuse.
Old Apr 5, 2009 | 11:45 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Yea, but the one that ties to the back of the head is the ground that counts.
Old Apr 5, 2009 | 12:09 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
come on now I wouldn't ask if I wasn't past the ECM and dumb SES light.
Why when looking up to buy a new ECM and found that service bulltin it starts to make sense.
read this thread
https://www.thirdgen.org/forums/dfi-...ble-codes.html
Old Apr 5, 2009 | 12:44 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Migth be getting somewhere
trace wires for the MAF to the MAF relay and its connector looks like crap, touch it just a little and the big brown wire going to it just fell out.
Old Apr 5, 2009 | 01:49 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Any way to test a MAF?
Lst thing I had done was move it around some.
I hear they got go form looking at them funny.
tried it with it unplugged and runs just as bas on start up.
Bad idle and back fire out the intake.
But get it over 1500 rpm it will run and idle for a few mins, then stumbe out and die.
Old Apr 5, 2009 | 02:41 PM
jv9999's Avatar
Engine: 5.7L/350
I think you need to look elsewhere. How's the vacuum at idle? How old are the plug wires? Distributor original?
Old Apr 6, 2009 | 07:29 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Its to on and off to be that.
Like someone throwing a swtich from full power to half power.
Old Apr 7, 2009 | 05:37 PM
There are not one, but three ground wires from the ECM going to two ring terminals on the engine, in addition to one wire being grounded in the dist.. So with 4 equal ground wires to three points, how'd you figure which one counts?
Gumby; the way you write things one can't help but wonder how much you've really checked.. You are holding back information and that certainly doesn't help us help you..
mddaniel
Sep 8, 2015 05:16 PM
Glowsock
Aug 31, 2015 09:01 PM
Jae992
Aug 27, 2015 09:07 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
stalkier
Aug 21, 2015 01:54 AM
