Fuel pump and oil filter
Old Apr 6, 2009 | 05:34 AM
nitemare70's Avatar
Car: 83 Z28
Engine: Comp Controled 350 w/ carb
Transmission: 5 Speed
This may belong in swap thread, not sure. I am putting a former TBI 350 in a carbed 83 Z. I am using an inline electric fuel pump at the tank(not in) and was looking for suggestions were to pull power from for pump. Would like it to be passive (no switch). Any Ideas??? BTW, it is staying carbed.
Also, the motor is AC/Delco reman and with 57kid's help figured it to be from 87-94 truck. The oil filter for said truck does not seem to fill the recession for it. What filter should I use???
Old Apr 8, 2009 | 07:45 PM
nitemare70's Avatar
Car: 83 Z28
Re: Fuel pump and oil filter
All right ya'll. help me out please. This motor just dumped a second load of oil on the floor from the oil filter. I thought I had the wrong one and tried another...same result. I have the fuel pump powered now, just need to understand why it fills the oil filter then the floor.
Old Apr 9, 2009 | 07:35 PM
nitemare70's Avatar
Car: 83 Z28
Problem with filter found but not solved!!!!!! It appears there is a blockage in oil passages. I got it fired up for the first time and no oil pressure. Shut it down and under the car is another puddle of oil. I feel the blockage is stronger than the filter seal and blowing out. Could this be a spun main bearing??? I figure after all this work, that is the best conclusion I can come up with. Any help with this would be nice. I seem to be the only one on this thread.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
